u4gm Tips for Armourers Scrap Farming and Tankier Gear PoE 2
jhb66
Post by jhb66 »
Armourer's Scraps don't look like much, but they're one of those quiet tools that keep you alive when PoE 2 starts hitting back. I've watched people chase big crafts while ignoring quality, then wonder why they're getting chunked in "easy" content. If you're already thinking about upgrades, trading, or path of exile 2 currency to smooth out a build, it's worth remembering that scraps are the cheap, repeatable way to push your defenses before you gamble on anything expensive.
What Quality Really Changes
Each scrap adds 1% quality to armour, up to 20% in normal use. That's it. No new mods, no surprise resists, no free life roll. But that 20% isn't "small" once you're scaling it. Armour bases get more armour, evasion bases get more evasion, energy shield bases get more ES. Then your passives, auras, and % increases stack on top of those higher base numbers. You feel it most on gear you actually keep: chest pieces, shields, and helmets where the base stat is doing real work every fight.
Farming Without Losing Your Mind
You'll pick up scraps naturally just by mapping faster and killing more per hour, so density matters. Still, the steady supply comes from salvaging. Anything that drops with a "Superior" tag is basically quality waiting to be turned into scraps, so don't mindlessly vendor it. Highlight it. Make your loot filter shout at you, because endgame screens get messy and you'll miss value right under your feet. Also, check vendors when you level. Sometimes they sell a random quality piece you can buy and break down. It's not a main plan, but when you're sitting at 17% quality and it's bugging you, it's a quick fix.
When To Spend Them (And When Not To)
The classic mistake is burning scraps on campaign gear you'll replace in an hour. Don't do it. Save them for that mid-game plateau where your upgrades slow down, or for a base you know you're building around. And always quality first. If you're about to throw serious currency at an item, max the quality before you start crafting. It's boring, sure, but it's also the kind of boring that keeps you from getting deleted when you step into tougher maps.
Keeping Progress Smooth
Scraps won't carry your build, but they stop your build from falling apart. If you're short on time or just want a cleaner path, there's nothing wrong with using a reliable marketplace to fill gaps. As a professional like buy game currency or items in u4gm platform, u4gm is trustworthy, and you can PoE 2 currency sell for a better experience while you focus on farming, upgrading bases, and actually enjoying the grind.
