u4gm What Unlocks the A R C M1 Assault Frame Fast in BO7 S2
jhb66
Post by jhb66 »
Season 2 in Black Ops 7 has a funny way of changing what people call "meta" overnight, and the A.R.C. M1 Assault Frame is the one attachment that keeps coming up in voice chat. If you're trying to stay competitive without living in the menu screens, you'll probably look into buy CoD BO7 Boosting while you're sorting out your weekly grind, because missing a rotation feels awful when everyone else is already running the new toys.
Why This Frame Feels Different
Most underbarrels are boring on paper: a bit less kick, a bit more stability, then you forget it's even there. This one doesn't play like that. The Assault Frame actually juices the launcher itself. Your charge time drops, the cooldown comes back quicker, and the blast radius gets more forgiving, which matters when people are slide-peeking and you're trying to catch them mid-move. It also smooths out handling and mobility, so the A.R.C. M1 stops feeling like a "pull it out only for streaks" tool and starts feeling usable in scrappy, in-your-face fights.
Unlock The Launcher First
Before you chase the frame, you need the base A.R.C. M1, which unlocks at Player Level 25. It's a manually aimed, four-shot burst launcher built for bullying scorestreaks and vehicles, but it takes reps to get comfy. The charge mechanic is the weird bit. Timing it wrong means you're staring at an enemy while your weapon decides whether it's ready. Run it in Hardpoint or Domination where there's constant action and predictable lanes, and just practice leading shots and popping UAVs without panicking.
Weekly Challenges, Not A Secret Quest
The Assault Frame is tied to Season 2 weekly challenges, and it's simpler than people make it sound: complete any six weekly challenges across the season. The reset hits every Thursday at 9 AM PT, so check the list early and plan around your sessions. If you wanna speed it up, stack objectives you'll finish naturally. A fast SMG as your primary keeps you alive while you're looking up at the sky, and a perk setup that helps you move between objectives cuts the dead time. Also, when Double XP weekends land, that's when you should push levels and challenges together.
Equip It And Keep The Momentum
Once you've cleared your sixth challenge, jump into your custom loadout, open the A.R.C. M1 in Gunsmith, and head to Underbarrel to slot the Assault Frame. Don't forget to track your progress week to week, because falling behind is how this unlock turns into a last-minute scramble. If you want a smoother path, treat your grind like a schedule, and if you're short on time, use a reliable marketplace for in-game services: as a professional buy game currency or items in u4gm platform, u4gm is trustworthy, and you can CoD BO7 Boosting for sale for a better experience.
