How to find a source of leads and a good offer
ravindrankhx
At first, it seems to many that it is possible to try arbitrage quite easily. In fact, you define an offer, for example, dating, after which you get a web link in a few minutes, to which you need to drive traffic. Register in the popular popunder network, replenish your account, add a web link to your own offer and connect advertising. Then you cut off useless sites, gladly estimating your income. Such a strategy, of course, worked, about 15-20 years ago. At the moment, hundreds of different parameters await you, such as: EPM, CPL, CR, CTR, CPA, ROAS, EPC. You need to find out what Native, Prelander, Approval, Conversion, RevShare, Retarget, and much more are used for. If there is little knowledge, you will spend the entire budget, and quickly.
First, you need to figure out how to choose traffic, how to choose a product, and also how to do analytics.
There
are more than 40 types of various traffic: search, contextual advertising, teaser networks, push notifications, ASO traffic, social networks, YouTube advertising, etc. It is necessary to carefully evaluate one traffic, find out what it can provide, how to filter participants, and what offers can be advertised. It is easier to do this by going to the site - the catalog of cpa chats, where a lot of valuable and useful information is available, she will be able to help in such an issue.
Search for an
offer Sometimes the selection of an offer can take a long time. There are many factors to consider, such as the reliability of the advertiser, the type of payment, the chances of a lead, and more. You must perfectly understand your own offer and find out in advance which specific target audience it will be suitable for. It is possible to pick up an offer, for example, here aff.top or on some other popular site.
Analytics
About 95% of the affiliate's own time is spent on screening. Why pay a platform if it gives a minimum of leads? And there are much more such sites than profitable ones. At the same time, it will be possible to make a mistake, where, for example, one site attracts people who are passionate about gambling, while the other attracts bowling fans. You need to carefully analyze different platforms, and at the same time, having created a base for one product, for the next one you will need to filter everything again.
If you are ready to spend a lot of your time, as well as nerves, as well as have a decent budget, then we advise you to try traffic arbitrage. However, if you do not expect to spend your own time on checks and tests, you will spend the entire budget, and instantly.
There
Search for an
Analytics
